Hey gsxr1100 and others.
   / Hey gsxr1100 and others. #1
Charolais
Platinum Member
south/central Va.
Deutz Fahr Agrofarm 100, Stoll loader, bucket, forks & root grapple
I'm still working with the hydraulic filtration on the tractors that I started on back in Jan. It just plugs in the remotes and filters from there with a 3 micron high pressure filter and a water removal filter that's low pressure and dumps back to tank. The water filter only takes part of the flow from the high pressure flow.
I've seen particles that look to be from the wet brake pads. The filter on the tractor won't remove those as it's 25 micron. I've also been able to remove some water with both filters. Then I've seen on the 3 micron filter something that appears to be wax. Not much but some. It gathers at the top of the filter cover/bowl.
My questions is, is there any way the filters can remove additives from the hydraulic oil?
   / Hey gsxr1100 and others. #2
I do not believe fluid filters (hyd) can remove additives. Maybe I am wrong, but that was/is my understanding.
Thanks Mike. I didn't think so either but the wax film I found in the top of the filter threw me. Never seen that on any filter before.
Thanks for your reply.
   / Hey gsxr1100 and others. #4
We have some hydraulic filtration down to .25 micron Beta 75 filters. I've not heard of filtration harming additives except for one instance where the wrong additive package was batched with the wrong base stock. The additive was falling out anyway and it just ended up in the filters as a gel type coagulant. How's the filtration coming now?
   / Hey gsxr1100 and others. #5
How do you get hydraulic oil to flow through a .25 micron filter? /forums/images/graemlins/confused.gif
   / Hey gsxr1100 and others. #6
My guess is pressure; or the efficency or capacity is poor and the fluid goes right by the filter media.
   / Hey gsxr1100 and others. #7
</font><font color="blue" class="small">( My guess is pressure; or the efficency or capacity is poor and the fluid goes right by the filter media.
)</font>
Either guess is wrong. I don't understand what you guys are saying? The media is tight but the filters cost a mint. They're extremely well built polyester media Hilco filters. Oil goes right through them, until they clog up. There is no bypass.
   / Hey gsxr1100 and others. #8
ok, what PSi are you running them on? And on what?
   / Hey gsxr1100 and others. #9
Gas turbine oil utilized in the hydraulic protection and control circuit, custom made Hilco sidestream filter, differential new is only 2.5psid, fed from it's own supply pump at less than ten pounds.
   / Hey gsxr1100 and others. #10
I know exactly what you are referring to.
I can't remember the micron rating on the hydraulic system filters on the GE frame 6 I now operate or the 7EA DLN I used to operate. I'm in the middle of an outage I'll have to check it out. I'm sure our filters are no where near that fine.
We could have probably used something like that on the 7EA. Used to have orifice plug up on the control oil to the distillate system when transferring to secondary fuel nozzles.
2001 MACK RD688S ROLL OFF TRUCK (A51243)
2001 MACK RD688S...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2015 FREIGHTLINER...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
