Hew holland 1620 wont move after it gets hot
   / Hew holland 1620 wont move after it gets hot #1
Prolinefisher
new holland 1620
I have a new holland 1620 that runs fine until it heats up and then it gets sluggish and wont move. The engine is fine it feels like it is in the hydro system. I have changed the fluid and filters but it does the same thing. I am pretty good at doing most repairs by myself but am at a loss here. The pedal feels funny and it whines when it si acting up. I would appreciate any help on this. Thanks in advance.
   / Hew holland 1620 wont move after it gets hot #2
Some have had air leaks on the suction side of the charge pump that get worse as the temperature rises. The noise is the symptom that suggests this.
Chris
   / Hew holland 1620 wont move after it gets hot #3
What did you figure out was the problem with your tractor? Have tc40d doing same thing,Want to make sure I cover all bases before I split tractor into to get to the charge pump.
2020 Kubota MX5400 (A50123)
2020 Kubota MX5400...
PREDATOR INVERTER 4550 WATT GAS GENERATOR (A51248)
PREDATOR INVERTER...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
THOMPSON INDUSTRIES INDUSTRIAL PUNCH PRESS (A51248)
THOMPSON...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
