Here's something...new
   / Here's something...new #1
farmboy12
Platinum Member
Benedict, MD
Kubota M4900 FEL; New Holland TC30 MMM; Ford 1620; Ford 1520 MMM; John Deere X740; John Deere 455 MMM; Craftsman 19.5hp;;;;; Antiques: 1946 John Deere B; 1951 John Deere MT; 1952 Allis Chalmers B; 1967 International 140
Okay. Please, I will mention things that we do that are totally wrong and should not be followed. Please, keep the comments related to the story. I know what we do is wrong.
I was moving the Cub Cadet 1450 that hasn't run for some time and is hydrostatic. Therefore, we can't manually push it very far with less that 2-3 people. So, I got a chain to tow it with the NH TC30. I realized pretty quick that I had a piece of connection wrong. So, I did something we do with all other hydros, but never with this NH, I was standing on the side of the tractor, lowest RPM, low range, and pressed slightly on the back pedal. Well, when I went to let pedal go, I remembered that the hydro on the TC30 sticks, and before I could fix it, WHAM!! It hit the cub cadet and drove itself right up with a wheel on each fender, but it kept spinning.:eek: I finally got to the forward pedal and drove it off. That little CC only broke a tail light!! I proceeded the tow. I couldn't do too much about it, knowing Pop might come down the driveway any minute.
Well, my heart was still racing a minute or two later! Be careful out there!!
Kyle
   / Here's something...new #2
Kyle
Just some advice, you should not push or tow a hydrostatic machine. There is usually a lever that you push or pull to release something so it can roll very slow and not for a long distance. Mine jammed up just by getting it off the truck.
   / Here's something...new #3
All the Cubs I've seen have a drive release on the back of the tractor. Sort of a rod sticking out the back, just above where you hook a cart to the back. The rod sticks out of a keyhole shaped hole. Pull the rod out and down, the keyhole shape holds it out.
J J is right..... you shouldn't tow them any distance without disconnecting the drive. Damage will result.
   / Here's something...new #4
Time to move this thread from safety to Cub Cadet Hydrostatic Transmission Repair...:(
   / Here's something...new #5
Back to the safety no no's, I'm guilty, I move my e hydro machine a few inches one way or another from the ground on the side of the machine, have to put one hand on the seat to satisfy seat safety and one hand on one of the pedals.
Also don't turn off the engine and set parking brake every time I hop off for a second. I'm bad :(
Regarding Cubs, I use to walk along next to my little hydro drive CC with lever on the dash :eek:
JB.
   / Here's something...new #6
Well,you learned another lesson! Right up there with that bunk bed lesson.
   / Here's something...new #7
Glad you are OK and no more serious damage was done. Thanks for sharing, I certainly learned from the story and JJ's comments.
Yea, JB, this is a dash drive hydro. I do the same thing.
JJ-
I know what you're saying. But when there is no access to a loader, and no one else there, you gotta do what you gotta do. It's fine now. It freed up during the tow. I got it started for about 10 seconds and drove it before it cut off. So the tranny is fine.
Kyle
   / Here's something...new #9
Regarding Cubs, I use to walk along next to my little hydro drive CC with lever on the dash :eek:JB.
My Dad had a JD 185 with the hydro lever on the fender years ago and got it
stuck next to the lake and there's a steep banked creek about 30' from the
lake , well he got off , moved the hydro lever to about half speed and began
pushing , it got unstuck and while dragging him he tried to move the lever to
neutral , he had to let go as it went down the bank and into the creek ...
:eek:
Later,x595
   / Here's something...new #10
Regarding towing hydrostatic L&G tractors, my G1800 doesn't have a release, so no towing with the wheels down -- seems like a dumb design.
My solution was put a ball mount into my 3pt hitch receiver (attached to my B7100HST) with no ball on it, and pin that to the sleeve hitch on the G1800, and then lift the back end of the G1800 with the 3PH and proceed to tow it backwards with the rear end off the ground.
Now, with hydrostatic tractors with multiple ranges, it is easy -- just put it in neutral.
2024 Jisan JS280RT Rotating Hydraulic Demolition Shear Excavator Attachment (A49346)
2024 Jisan JS280RT...
Nissan 5K Propane Forklift (A50397)
Nissan 5K Propane...
UNUSED Clear Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Clear...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
