Here we go again
   / Here we go again #1
AMP762
s.c.
Mitsu D1550 Farmall super A
I got this from another site,so I pass it along. I am not a chemist nor do I play one on tv.
Effective June, 2006 diesel fuel (No: 1 and No:2) is required to be
15ppm MAX on sulfur and will be called Ultra Low Sulfur Diesel or
ULSD. Current Low Sulfur Diesel (LSD) is nominally around 300ppm
Sulfur. This is an EPA TierII Clean Air Act mandate and 99% of the
reason Diesel has gotten so high in price compared to gasoline. I
know our little grey's are so fuel efficient, none of us spend a
great deal of time searchng for $$ for fuel, but I wanted everyone
to know that removing the sulfur also takes away the wonderful
benefit of lubricity. Lubricity in diesel is measured by a test
called the High Frequency Recipricating Rig or HFRR. We call it a
Heffer here in Texas ;-). The Europeans have been running on ultra
low sulfur diesel for quite some time and set the HFRR requirement
at 460 (the lower the better) and the EPA and ASTM set the US
requirement at 520. The number is the measurment of wear scar
similar to the wear we will see in our engines in the area which
does NOT get lubricated much by the engine oil cylinder walls and
injector pumps. Lubricity additves are added to the fuel at the
wholesale truck rack or at the loading terminals to meet the 520
spec. Look for a whole host of aftermarket lubricity additives to
come out, I suspect. Don't be fooled by those who advise to put a
few drops of oil in your fuel - that doesn't do anything but provide
the carbon molecules to build up and plug injectors and clog
valves. Also don't be fooled by what they call OFF Road Diesel (aka
Red Diesel or High Sulfur Diesel (HSD)) after June 2006, most
refiners don't have the tankage to keep both in stock so they merely
sell the ULSD as Off Road. With the requirement for ULSD at 15ppm,
there is no way to keep the refinery and terminal pipes and hoses
clean enough with any 300 or HSD around. HSD used to be about
3000ppm in the old days.
If I hear of anyone who has a national brand of lubricity enhancer
on the market that really works, I'll let the group know.
This ain't no bull folks - I'm an automotive engineer, tribologist
and work for refiner in operations (quality and laboratory
services). Most importantly I'm a proud owner of a 1979 model Mitz
D3000.
I bought about 15 "Heffers" last year to prepare for June - they
ain't the ones with four legs ;-) We spent $BILLIONS building the
equipment to reduce the sulfur.
   / Here we go again #3
Gotta live with it, I guess.
What about grinding up match heads and putting them in the tank?
   / Here we go again #4
Thanks for the heads up,please keep us posted.I have heard of some farmers and truck drivers putting marvel mystery oil in their tanks for lubricity does this really do anything good???
   / Here we go again #5
Here we go again...but before we go there, lets ask ourselves where did we go the first time?
The first time sulfur content was reduced in diesel fuel, we suffered from less sulfuric acid and soot in our crankcases, which led to longer oil change intervals. The reduction in sulfur also led to cleaner air to breathe.
I expect similar dire results this time. But we could ask the Californians--they've been running it for a while already.
Someone mentioned the kitchen match. That might give us insight into the the lubricating qualities of sulfur. It seems to me that something that bursts into flame from the heat caused by the friction of scraping along a surface for 1/2" is probably not a very good lubricant.
   / Here we go again #6
You might have guessed correctly that I was yolking.
The new regs are probably based on reasons having to do with air pollution. I am somewhat more concerned about the air I breathe than how long my injector pump lasts. Now if the reasons are bogus, then that is a different story. I don't know if they are bogus, but I suspect they are not.
   / Here we go again #7
</font><font color="blue" class="small">( Thanks for the heads up,please keep us posted.I have heard of some farmers and truck drivers putting marvel mystery oil in their tanks for lubricity does this really do anything good??? )</font>
This may be a push for an increased use of Bio-Diesel. If not, it will certainly be an increased usage of fuel filters.
   / Here we go again #8
Thanks for the info on the timing (e.g. June).
Are you both an auto mechanic and and automotive engineer? You show auto mechanic as your profession when we click on your name.
Have they actually done long term tests on injection equipment to come up with these required test numbers? I really don't understand how sulfur is a lubricant. In the lube oil industry, some of my cohorts were guessing that some tiny amount of sulfur in lube oil helped its lubricating properties, mainly by acting like a vulcanizing agent to help keep it from breaking down. However, hydrocracked oils and synthethic oils with ZERO zulfur did better, mainly because they needed FAR less long chain additives to meet specs.
Ralph
Lube process engineer in my past life
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2018 KUBOTA SVL95-2 SKID STEER (A52705)
2018 KUBOTA...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
