here we go again LS troubles hour 56 pto solenoid and more
   / here we go again LS troubles hour 56 pto solenoid and more #1
deer assassin
Kingston Springs TN
2017 LS XR4145HC 1967 oliver 550 gas
Hour 26 the solenoid coil went out
http://www.tractorbynet.com/forums/ls-tractor-owning-operating/383678-pto-will-not-engage-ls.html
well yesterday i was cutting with the bush hog the cruise control would not work it acted liked it would try but would not lock
then in the last hour it started working but this morning again it would not engage
one hour in to cutting this morning pop fuse blown on pto solenoid i disconnected it and it will NOT blow fuse connected it will pop when you turn the switch on
again what the heck is the coil only good for 26 hours it went out at 26 and now 56
i am starting to regret buying this tractor
after a nap i got up and did a lil food plot prep
i really do enjoy the tractor
enhance
enhance
   / here we go again LS troubles hour 56 pto solenoid and more #3
Under powering a coil will cause it to draw more amps, heat up and fail after a short time. Check to make sure you are getting 12+v at the coil.
i will have to check that
dealer mailed me a new coil and valve yesterday
valve was wrong mine is the smaller how ever the coil was correct
i put it on all is good for now
enhance
enhance
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
2012 RAM 5500 (A52472)
John Deere X310 Riding Mower (A50515)
John Deere X310...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
