Seeders Herd seeder new M-96 or used 750
   / Herd seeder new M-96 or used 750 #1
Baranx4
Northeastern, Pa.
I can get either the m-96 new or the herd 750 used. It seems the M-96 fits my uses better but the used 750 would be abut $200.00 less than the M-96 and it's in excellent condition just a few rust spots. I had given the guy a very low offer then it was listed local and now if I want it it's mine since it didn't sell for what he was asking.
The 750 is a big unit and my concern is if it will be an overkill for what we're doing. I'm only going to be farming at most 30-35 acres of open field.
I had posted about the 750 before but only got one reply.
THanks
   / Herd seeder new M-96 or used 750 #2
I've got a Herd F-160, which is essentially a larger version of the M96. (They're no longer in Herd's line-up) I also share ownership of a model 750 spreader with my brother-in-law. The M96/F-160 is a really good seeder. The 750 is a much heavier duty SPREADER. It'll handle big loads of fertilizer, lime, ect. An issue to consider, can you use the larger size? With a full load of fertilizer, will your tractor handle the weight?
But.....also worth considering, the bargain on the 750 might enable you to buy it, use it, and re-sell at a later date. They're VERY popular spreaders.
My tractor can handle the 750. I was concerned about it being able to seed as well as the M-96.
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A55745)
MCELROY 500 SERIES...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
43030 (A51691)
43030 (A51691)
2006 CHEVROLET SILVERADO 3500 FLATBED (A55745)
2006 CHEVROLET...
500BBL SKIDDED FRAC TANK (A55745)
500BBL SKIDDED...
