3-Point Hitch Helppppppppppppp
   / Helppppppppppppp #1
Powerstroke-03
I have a Mahindra 6000 and the 3-point hitch and the loader will not raise. It was low on hyd. oil fill it up and still dont work. Anyone have any ideals what could be wrong? Oh the 3-point will raise until it get weight on it then nothing.
   / Helppppppppppppp #2
Keep working it. It sounds like air in the system, you'll just have to work it out.
   / Helppppppppppppp
Thanks ToadHill, been working it for 3 hours and still nothing, pull high pressure line it seen to flow through it good. Any other suggestion.
thanks in advance
   / Helppppppppppppp #4
The 3PH drop adjustment knob below the seat, remove the stopper bracket on it and then close the valve. Then start the tractor and pull the position control lever to the up position and cycle it up and down a few times. Then put the stop bracket back on the knob. If you have some trash in the relief valve, this process should dislodge it and hopefully solve your problem.
   / Helppppppppppppp
Galen, tried no luck, I have taken every line loose including line on bucket cylinders and joystick control they seem to have plenty of hyd. oil coming throught. If you rev the motor the 3-point hitch will raise without a load on it put attachment on and it will not lift at all even with motor rev. up. Do you think the pump has gotten weak?
   / Helppppppppppppp
UPDATE There is a plug on the left side of the joystick pulled it and move joystick sideways put plug back on and all is well thanks for the suggestion
   / Helppppppppppppp #8
I believe the plug that you removed, is the loader bypass valve.
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2021 Western Star 4700SF Tri Axle Dump (A47384)
2021 Western Star...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
2014 Dodge 5500 4X4 Bucket Truck (A52128)
2014 Dodge 5500...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
