JATO_RaT
Veteran Member
We lost the pilot light on our floor furnace at our cabin at Lake Tahoe. A bad pilot generator. Everything froze, 3 broken pipes inside and split toilet fill valves. I repaired all the leaks, and am drying things out.
My question I figure might be answered by you folks out in the Midwest or East coast. Since this cabin is not occupied continuously, I would like to shut the water off when were not there, but the problem is, we have renters, to ask them not only to turn it on, shut off a drain valve for the pipes and do everything in reverse when leaving could prove a problem. Is there another way. We will still leave the furnace on 45 degrees, but should we ever loose the pilot light again, this problem will happen again. I would like to see something like a 12 volt valve ( 12V for battery backup/run) where a simple flip of a switch that has the ability to turn the water on or off as well as drain the system depending on the result desired, (coming or going) Anyone ever heard of this type of setup? Any other advice. Tahoe gets cold, down in the 20's and sometimes into the teens, but thats about it. Thanks, Rat...
