Help!!
/ Help!! #1
swampvol
SC
Kubota l3400HST TLB
I just changed the hydro fluid, for the 2nd time, and am having some problems.
I changed it at 50hrs, no problems, the only difference now (200 hrs) is while changing I replaced a quick-attached that had been leaking ever since I had the backhoe installed..
I can go forward and reverse, curl the bucket and lift and lower the fel while curling, but I can't lower or raise the 3-point, nor the fel straight up or down.
I'd guess that I have air in the lines, but working the fel and 3-point for the last 30 minutes isn't working.
L3400 hst.
Any help would be much appreciated.
/ Help!! #2
My guess is that new quick connect didn't seat properly when you reconnected it or it is not the correct fitting to match what you already have. If you only did those two things, that is atleast where I would start. It should only take one cycle to bleed any air out of the lines.
