Help
   / Help #1
poundingmill
I just bought a JD 3005. I've never had a tractor before and I've been reading the owner's manual. The manual recommends using a torque wrench to tighten the wheel bolts and the loader bolts.
I dutifully bought a beam style torque wrench and now I can't get this long wrench up close enough to the wheels to torque the bolts. Do I need an extender? Should I use another type of wrench?
Any suggestions will be greatly appreciated.
   / Help #2
Just use a 6" extension on your wrench to check torque. Using the extension will result in a negligible loss in the torque, so set your wrench a couple of feet-lbs (or newton-meters) above the manual's values.
Deflecting beam torque wrenches are robust, but not as easy to use as a micrometer setting (click type) wrench. It's tough to read the torque on the deflecting beam when you are tightening. You might want to invest in a micrometer setting type wrench. If you do buy one, turn it back to zero when finished using it. Leaving a micrometer setting torque wrench set a a value can result in the torsion bar taking a "set" and losing accuracy.
   / Help
Thanks for the suggestion, Roy. I'll certainly try that.
   / Help #4
Even easier, you can get a torque limiter for your air gun. I have tested these with a freshly calibrated Snap-on torque wrench and found them very accurate.
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2017 Volkswagen Jetta (A50324)
2017 Volkswagen...
