Help with wiper seal Case 580
   / Help with wiper seal Case 580 #1
Painter Motorsports
Greensburg, PA
1986 Case 580 SE
I have a question on how far down does the wiper seal seat on the hydraulic cylinder. I have changed a lot of rear end and pinion seals that have a flange on outside that seats the seal. On the wiper seal it does not, how far down do I seat the seal. The old one was flush with the gland nut and had about a 1/16 space under it. Do I install the new one the same depth(flush) or seat it in further till it bottoms out on the machined lip. Thanks for your help.
   / Help with wiper seal Case 580 #2
I really dont think it matters but I always stop when they are flush @ the top. It makes them easier to remove next time because you can get a screwdriver under it to get it out. If you drive them all the way down they can be tough to get out.
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2016 Kenworth T880 Tri-Axle Brenner Tanker Truck (A51692)
2016 Kenworth T880...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
