Help with Vickers Pump Specs
   / Help with Vickers Pump Specs #1
tkelly0224
Bow,nh
M101A2
Hi Guys, Can anyone help me identify this Vickers pump? We just picked it up today to mount on the MF65. I just cant seem to find any info]on it such as GPM. Thanks
   / Help with Vickers Pump Specs #2
What is the number after the V210? is it a 2, 5 or 6? This would be the GPM flow rating at 1200 RPM.
Maximum speed 1800 RPM
Maximum pressure 2,000 PSI
Right hand rotation as viewed from the shaft end
SAE - A mounting flange
Thanks for the help. That missing number has been killing me, I have no idea how much this pump will put out. I did a ton of research, how did you find all this information on the pump? Are parts still available for it?
   / Help with Vickers Pump Specs #4
I have been in the Fluid power industry for 30+ years and have saved some old paper books with information in them.
NOTE: If you are lucky there could also be a number stamped on the cam ring next to the direction of rotation arrow if this old pump has the direction of rotation arrow. This number would also be the GPM produced at 1200 RPM.
Parts may be available but not 100% sure since these have been replaced by the V10 or V20 series. Attica Hydraulic Exchange may have parts or rebuild kits for these. Also try an Eaton Vickers distributor in your area.
Do a Google search for Vickers M-2032-S. This should get you the parts manual for your pump.
Thanks so much for the help. I was a bit apprehensive parts would be hard to find. Can i boost the GPM if I change out some internals? I really want to get to the 11 gpm range without having to spend $600 on a new vickers pump.
FRONTIER WR3212 LOT IDENTIFIER 54 (A53084)
FRONTIER WR3212...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
