Help with two speed rear axle on my dump truck
   / Help with two speed rear axle on my dump truck #1
rexcramer
Birch Run, MI
Case 580C
I have a 1987 GMC 7000 series dump truck with a two speed rear end. Well yesterday when only slightly stuck I snapped an axle. Now I cant get the axle out on the other side to tear the rear apart.
The axle comes out about 3/4 of an inch and then stops. My only guess is that some material from the other axle is jammed in there somehow preventing the good axle from coming out. I am assuming there is no retaining clip holding the axle in right? When I pull the bolts on the gear assembly and move it the axle moves a little so I know its still in the gears.
Thanks for any tips
   / Help with two speed rear axle on my dump truck #2
If your diff has a diff lock it may be the type that has twin splines on the axle shaft , some 2 speeds are the same . You may need to turn the axle fore and aft a little to get the second spline to line up before it will come out . A little trick with broken axle ends . Have someone hold a 5' length of conduit in against the hemisphere bearing so that when you drive the broken piece out it does not fall into the housing , it will lay inside the conduit and can be withdrawn negating the need to pull the diff center . Use a 5' piece of 1/4" steel rod to drive the broken piece out from the other side , the rod will pass the sun gear pin and reach the axle spline .
There is no differential lock. So I should be able to drive it out from the other side? When I look in the axle housing I can see some material from the busted axle in there. Thanks for the reply
2013 John Deere 824K Wheel Loader (A53473)
2013 John Deere...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
