Help with Tractor Bolts
   / Help with Tractor Bolts #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
Hi, They said this was the place if you have a tractor question. So... Can anyone tell me where all these bolts go on a 2120. Thanks in advance.!! /forums/images/graemlins/grin.gif
Pic 1
Pic 2
Hope the images show up.
Actually just showing off some of my garage zinc plating. The stuff came better than I expected, the chromate is thick and shiny. Had all the sheet metal painted last week.
   / Help with Tractor Bolts #2
Wow...you've really got problems. I was worried when I found ONE bolt in my drive /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif.
A home plating operation...that could be handy. Those look as good as anything I've ever bought.
I've found that I can put on more zinc than stock - 0.001 in which is a lot by plating standards. Some commercial bolt are in the micron range. Plated my drag link turnbuckles as well. Use it on my boat engine parts too. Topcoats comes in 3 types Black, Yellow Dichromate, and Olive drab.
   / Help with Tractor Bolts #4
Could you give a description of the equipment and process involved?
   / Help with Tractor Bolts #5
<font color="blue"> I've found that I can put on more zinc than stock - 0.001... </font>
How does that affect the tolerences between nut/bolt? Does it give a little more resistance in the threads?
Doc. Here is the link to the kit I use.
Caswell Plating . I bought just the chemicals and the color etches. I had a good power supply and the other stuff. I just used boat zincs for the anodes - prevalent in my area.
Doesn't affect the thread fit any that I have noticed. However it is very controllable with the current /voltage setting. Takes about 50ma per sq. in. @ 0.6vdc.
2014 Freightliner M2 106 Altec DC47T Insulated Digger Derrick Truck (A50323)
2014 Freightliner...
2015 DODGE RAM...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
INSPECTION (A51572)
INSPECTION (A51572)
2022 FORD F-250 SUPER DUTY (A52472)
2022 FORD F-250...
43013 (A51691)
43013 (A51691)
