Help with Toro zeroturn
   / Help with Toro zeroturn #1
Gomer pyle
Murfreesboro, TN
John Deere 5090E
I have a '16 Toro Z-Master 2000 with a 23hp Kawasaki and 98 hours. Went to start it last weekend to start servicing it and the battery went bad mid crank(bad cell). I replaced the battery and was able to do everything accept hydro filters(had the wrong filters, thankfully I looked before unscrewing). I tried to start it Friday afternoon to do hydros and all it would do was click. I have checked everything I can think of.
I temporarily bypassed the seat switch, and checked the brake and control levers(I hear a clicking noise when they engage the button). While checking the key switch, I accidently crossed two spades and it started. I assumed bad key switch. I picked up a new one yesterday and the same thing. Nothing with the key but starts if I cross it out. I did try to cross the solenoid and got nothing.
Any ideas? I'm pulling my hair out.
   / Help with Toro zeroturn #2
There is probably a starter relay that you may need to check also. Had one go bad on MY BOBCAT zero turn with Kawaski same symptoms.
   / Help with Toro zeroturn #3
Check the ground, and the seat switch. Spent many an hour wasting my time and now I check these first. Good luck
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53473)
2020 Westfield MKX...
1992 SHOP MADE CHASSIS TRAILER (A53843)
1992 SHOP MADE...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
