Help with sticking float on Ford 600 series
   / Help with sticking float on Ford 600 series #1
Victor23
Central Florida
Ford 600
My 600 has a float that sticks way too often. If the tractor sits the gas will pool in the air intake. Any suggestions?
I may just have to do a carb rebuild. It has one of the old Marvel carbs.
Thanks.
   / Help with sticking float on Ford 600 series #2
It's probably just some crud betwixt the needle and seat... but.. you should be turning the fuel valve off for safety anyway.
Go ahead and flip for the 'small' rebuild kit ( no float ).. and a can of carb cleaner... If that is the only probelm, you should be good to go.. A toothpick polishes the float set nicely.
I like the marvel carbs a whole lot better than the zenith.
check to see if the sediment bowl needs to be serviced..
Soundguy
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
