Help with PTO shaft removal
   / Help with PTO shaft removal #1
darien7
Central Florida
Yanmar YM336
Help- I snapped off the PTO shaft on my YM336 and am having trouble in it's removal. I have removed the bracket, spacer, 2 snap rings and large washer that is in the rear of the gearbox and now am looking at a bearing that appears pressed onto the PTO shaft. Should the pto shaft and bearing now slide out together, (I have tried and cannot budge it), or do I have to go into the gearbox to remove?
   / Help with PTO shaft removal #2
You will have to remove the hydraulic lift assembly. This is not an easy job. I would invest in a YM336 service manual.
Danny
   / Help with PTO shaft removal #3
Sorry to hear about your problems.
Ok.. I'm dieing to know.. how did you manage to snap that beefy 1 3/8 pto stub off? /forums/images/graemlins/shocked.gif
Soundguy
Not a good memory, but here is what happened. I was bushhogging and the clip that secures 1 side of the 3 pt hitch disappeared??? and wa laa , the hitch came off when I made a turn.
   / Help with PTO shaft removal #5
If it were me,I would remove it from the rear of the machine.
If you loosen the bolts around the pto shaft, it should slide out in one whole unit with the gears attached.
Thats how all the grey ones are removed, then you can repair it on a workbench. /forums/images/graemlins/wink.gif
Ernie
   / Help with PTO shaft removal #6
ouch... that same clip on my 3-pt arm sway chains have disappeared on me too... Good to know what can go wrong... good luck with the repair!!!
Yeah Ernie, That is what I would like to do, however, it will not let go of something inside the box. I have attempted to slide it out. There must be more to it
   / Help with PTO shaft removal #8
</font><font color="blue" class="small">( that secures 1 side of the 3 pt hitch disappeared??? and wa laa , the hitch came off when I made a turn. )</font>
Did you have a toplink hooked up? I'm surprised that the other 2 links let it move enough so tha tthe driveline ujoints didn't take up a bit of that slack instead of just poping the shaft off.
Soundguy
   / Help with PTO shaft removal #9
Try shifting it into 3rd gear first out of 4x4
If that doesnt work try the other gears
Ernie
   / Help with PTO shaft removal #10
Its not the bolts around the shaft.
Its the bolts that hold the complete unit, the outer ones
about 6-8 of them
2023 CASE TV620B SKID STEER (A51246)
2023 CASE TV620B...
Volvo Water Truck, 3306 Cat Engine (A52384)
Volvo Water Truck...
2019 JOHN DEERE 560M LOT NUMBER 139 (A53084)
2019 JOHN DEERE...
UNUSED HURRICANE G350 PORTABLE CEMENT MIXER (A51248)
UNUSED HURRICANE...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
