Help with Post hole digger disassembly
   / Help with Post hole digger disassembly #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I have a Leinbach post hole digger that the seal leak like a screen door. It is the normal sized unit which I think is rated to 40hp.
I pulled most of it apart and am having a problem with finishing the disassembly. I have the top off and got the "large" gear out but don't know how to get the small gear and post out. The small one is the one that the PTO shaft connects to. The shaft has a seal on the outside that is installed crocked. It still turns fine but really leaks and leaks bad. It also appears to be a tapered bearing of some sort. I thought the PTO post will drive in but I tried that several times without success. On the inside I have the gear so it will not go through to the outside and I figure it would be hard to seat it from the inside to it only makes sense that the whole shaft must go inward to be removed. I also have NO idea how to remove the seal(also tapered bearing maybe). I also was wondering where I should get the new seals since I can't find anyone around here that has a clue to where I can buy them. Any help would be great!!!!
Thanks!!!
Forgot - the bearing (I think are) "Corteco"
   / Help with Post hole digger disassembly #3
Give Leinback Machinery a call. I have always found them more than helpful. They can also advise you how to disassemble the gear box on the post hole digger.
Leinback Machinery
9125 NC 67 Highway
East Bend, NC 27018-8079 map
Greensboro-Winston Salem, NC Metro Area
Phone:(336) 699-3000
Thanks - I see it lists a clip below the oil seal... that maybe part of it. Now to find out how to get the seal out to check for the clip?
THANKS
   / Help with Post hole digger disassembly #6
The clip is there or the ring gear would have shoved the bearings out of the case.
If it's high on one side use a small screwdriver and hammer on the outside diameter of the seal to knock it inward. When it distorts inward just a little do the same thing on either side, the seal should come out.
You don't need to tear anything else apart but you should grease the lip of the new seal before installing it.
Is there a metal piece to the seal or is it just rubber. I have no idea what I am looking at because it is all painted and appears to be installed incorrectly.
   / Help with Post hole digger disassembly #8
The seal is most likely metal with a ring of rubber that seals against the shaft. It will look like a very shallow cup with a large hole punched in the bottom. I have seen a very, very few where the entire metal piece is covered in rubber, but removal and installation is the same in either case, crush it back a little and it will come out.
Great call Argosy - your directions worked perfect -got it out in about 5 minutes!
Thanks.
Any idea where I can buy new ones if the manufacture does not offer parts?
   / Help with Post hole digger disassembly #10
Seals are a standard item. Any NAPA, ORileys, etc. should be able to match them up. Take the old seal with you. Would be helpful to know the shaft size, bore diameter and width of the seal if it was destroyed removing it. Install it with the lip toward the inside of the case and like was said, lube the lip of the seal.
Kim
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A49461)
2014 Peterbilt 320...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A49461)
2005 International...
3in Poly Pipe (A49461)
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
