Help with peddles
   / Help with peddles #1
apeckham
Mahindra 2638
Have a question that I'm hoping someone has a fix
I have a 2638 HST , the peddles on the right side ie forward and reverse peddles are 2 1/2" off the deck. The peddles on the left side ( break peddles) are 5 3/4" off of the deck.
I can operate the forward and reverse peddles with my heel on the deck,but the break peddles are so far off of the deck that I have to lift my leg up to operate the peddle. Having to do this for any periods of time is very taxing. My left leg is partially paralyzed .
Has anyone else had this problem? How did you fix it.
Thanks , Alan
   / Help with peddles #2
May I ask why you're using the brake pedal(s) so much? Whenever I let off of one of the right pedals, I stop almost immediately. Sometimes I "touch" the reverse pedal to come to a stop even quicker. Only time I use the brake pedals is to park on a slope.
If you're getting "creep", be sure to grease and lube the forward/reverse linkage under the operator deck.
   / Help with peddles #3
He probably isn’t using the brake pedals a lot but with his partially paralyzed leg it gets very difficult and painful very quickly .
Maybe consider making a block of wood the correct height to make the brake pedals easier to reach with your bad leg, you could probably use a little silicone to hold the block in place.
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
2015 DODGE RAM...
2010 Dodge Grand Caravan (A50324)
2010 Dodge Grand...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
