Help with New Idea 318 Manure Spreader
   / Help with New Idea 318 Manure Spreader #1
JesseH
Hemlock, NY
New Holland
The chain came off while spreading manure, and one of the bars got bent for some reason, perhaps getting caught on something, and had to be replaced. Upon getting the bar and chain back on, the conveyer does not move when turning the PTO.
Is there a type of safety mechanism that is triggered when something like that happens? Unfortunately I don't currently have the manual for the spreader.
Thanks for any help!
   / Help with New Idea 318 Manure Spreader #3
Is it a 318, or 218..?? I looked at the AGCO site, and it doesn't show a 318, but does a 218.
When the pto is engaged, are you getting rotation on the gear box, at the back, or anything moving at all..?? From looking at the exploded view of the 218 drive assy. at the rear, there is a clutch mechanism to engage the apron drive. Could be this kicked out, or a problem with one of the pawl's, that engage the ratchet wheel.
Here is the link to the AGCOPartsBooks:AGCO Parts Books
Enter as a guest viewer by clicking on "view books".
Then type in 218, in the model number block. Click on the arrow far right where it says All Models. A list of manufacturer's will appear. Scroll down to New Idea, and click on it, then click on search.
Select the 218 manure spreader that appears on the next page that appears.
On the next page that appears will be a list of segments of your spreader. Look/scroll on down to page 20, which show the drive shaft assy., and there on. When you click on one of those segments, to the right, a page will appear with an exploded view of that segment, and a parts listing by name, and part number.
Page 28 shows the pawl/ratchet wheel assy., and the drive clutch assy. in one view.
The exploded view is small, but there is a + & - above the exploded view, near the blue line to enlarge the view. Should give you an idea of what to look for.
I'd guess either the clutch disengaged itself, or you've bent a pawl.
   / Help with New Idea 318 Manure Spreader #4
On my 3622 NI there is a shear bolt that connects the drive gear to the apron'S tri-lobed drive wheel that actually drives the apron chain.
2013 Volkswagen Passat Sedan (A51694)
2013 Volkswagen...
10" Shaver Post Driver (A52384)
10" Shaver Post...
1264 (A50490)
1264 (A50490)
2022 RHINO X1808 LOT NUMBER 65 (A53084)
2022 RHINO X1808...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A51247)
UNUSED LANDHERO...
