Help with my snowblower
   / Help with my snowblower #1
fredfrench474
Litchfield, ME
Massey Ferguson
Hello,
I am having an issue with my AGCO snowblower model SB550A. I am continually breaking shear pins and it appears that the auger is rubbing against the bottom of the snowblower shell which has created some pretty big divots in the metal.
It seems like the auger needs to come up but do not know how to do it or if it is possible.
If any one has any suggestions on how to fix this problem it will be greatly appreciated.
Fred
   / Help with my snowblower #2
Sounds like a bearing is wore out,where you have the slope in the shaft.
   / Help with my snowblower #3
Using a large bar try prying on the auger to see if it has movement in the bearings.
If not, then the blower cutting edge may be bent up.
Watch the auger center shaft as it turns to see if the auger itself is bent. Try and ignore the flighting (the part that moves the snow to the center) as you do this.
If you find the cutting edge bent, then a sledge hammer may solve the rubbing.
If it is the auger that is bent then you may need help from a machinist depending upon your skill and tools.
Dave M7040
2013 Nissan Rogue AWD SUV (A51694)
2013 Nissan Rogue...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
LMC LOT IDENTIFIER 126 (A53084)
LMC LOT IDENTIFIER...
