Help with Montana Rotary Cutter
   / Help with Montana Rotary Cutter #1
weh111
Deland, Florida
Montana 5740C
I have a Montana 7' rotary cutter, MHDRC8480SC, which I bought new many years ago. The tail wheel began plowing beautiful furrows and on disassembly it looks like bearings were never installed in the hub. I have what appear to be hardened races which have worn grooves in the shaft. I kept it greased but I guess this says a lot about my level of awareness.
The shaft is about 7.25" long by 1.0" diameter with a castle nut on one end and a flat disc on the other. The disc has a chord removed and it mates with a matching chord welded on the fork. If anyone knows the supplier of this cutter or has an idea of what company's parts might work I'd sure appreciate the help.
Thanks in advance
Bill
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
STORAGE FEES (A51222)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
