Oil & Fuel help with Mitsu MT2001X
/ help with Mitsu MT2001X #1
rjhend
I have had this tractor for a few years. Now I have oil coming out the dipstick even when not running. I have changed oil and filter and it is not overfilled. Any ideas?
/ help with Mitsu MT2001X #2
check your hydraulic oil level. If it is low you may have a blown seal in the pump.
/ help with Mitsu MT2001X #3
If you have oil coming out the dipstick tube with the engine shut off,then your oil level in the block has to be higher then top of the dipstick tube.Does the oil stop coming out shortly after you shut it off ? If so ,what is happening is your engine is building up to much crankcase pressure and forceing the oil out.If there is a crankcase breather it must be plugged.Try running it with the oil filler cap on the valve cover loose or off and see if that stops it.Most times to much crankcase pressure is caused by bad piston ring seal (to much blowby),lets hope its only a pluged breater,re-ringing can be expensive.How much oil is your engine burning,is it hard to start and do you get blue smoke
out the exhust when under load. Keep us informed
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2022 Morbark Eeger Beever 1215 Towable Brush Chipper (A59228)
2022 Morbark Eeger...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2014 Jacobsen Groom Master II Bunker Rake (A59228)
2014 Jacobsen...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
