help with me NH tc40
   / help with me NH tc40 #1
Rick1397
Delaware
Tc 40
I recently bought a 2002 New Holland Tc40 with front end loader. While using it started to sputter/ stall and Died, It was used when I purchased it and I dont have a service Manual. It appeared to be out of fuel ( the float must not be working) so I put fuel in it and purged any air from the fuel filter and the Block ( not sure what it really is called Distributes fuel to all cylinders) cranked it over and it attempted to start but never really did. I have checked all of the easy things that I know of like the pto,seat and transmission switches and still cant get the engine to start. I have been reading this forum for quite a while and am very impressed with how knowledgeable you guys are so I am asking for help with this problem. I can do mecha:confused:nical work Im just very inexperienced at diagnosing problems. If anyone can think of something that it could be or of something that Im missing I would greatly appreciate the help....
:confused:
Rick
   / help with me NH tc40 #2
First off is this tractor a diesel? Did you run it out of fuel? If you ran it out of fuel you need to bleed the lines starting at the main fuel lines to the injectors in that order. If it didnt run out of fuel you probable have trash in the lines and the only way to remedy that is start at the tank pull each line loose to see if you have a good flow. once you find the blockage re-bleed the lines.
   / help with me NH tc40 #3
Change the fuel filter first. If you have alot of debris in filter; make sure you have good flow TO the filter. After replacing filter, bleed lines at injector pump. If still no start, you may have to bleed at each injector. REMEMBER to put a battery charger on battery while doing all bleeding as you will wear down battery. REMEMBER that when loosening any injector lines, high pressure will be present when cranking engine. DO NOT USE ANY TYPE OF STARTING FLUIDS!
Thanks Guys !! Im working right now but when I get home in the morning I will try your suggestions!!
Yes the tractor is a diesel, it was low on fuel however I think that it still had some.
I guess the next project with be replacing the float in the fuel tank!!!!
Thanks again
Rick
Thanks Again!! this morning I replaced the fuel filter and check all of the hoses noted some particulate mater in the fuel from the hoses, I drained all of the fuel and replaced with fresh stuff, purged the air and she started....I appreciate all your help
Rick
   / help with me NH tc40 #6
i will give this a try also.i just checked and the fuel is running good at the injector pump
2005 Ford F-750 Crew Cab Heil 5 Yd Mason Dump Truck (A51691)
2005 Ford F-750...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
8ft Forklift Safety Basket Attachment (A51691)
8ft Forklift...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
