Backhoe Help with M4700 backhoe question
   / Help with M4700 backhoe question #1
clark_bailey
I have a m4700 and I have been told I can not use a backhoe. Kubota said that the top link is weak and that the draft sensor in the top link will wear out if I use a backhoe. The other question is when the hoe is attatched to the tractor I cannot raise the lift arms more than a few inches, is this normal or should you be able to raise the hoe like any other 3 point implement? Thanks for any help. Clark Bailey
   / Help with M4700 backhoe question #2
Does the tractor have a loader? What kind of backhoe? Normally a special top link bracket is added with the backhoe mounting kit specifically for those tractors. This bracket would basically take your draft control out of commission.
2006 BOMAG BW5AS DOUBLE DRUM COMPACTOR (A51242)
2006 BOMAG BW5AS...
2011 JCB 515-40 Telehandler (RUNS) (A50774)
2011 JCB 515-40...
(UNUSED) 2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
(UNUSED) 2024...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
Land Honor Skid Steer Blank Plate (A50514)
Land Honor Skid...
