Help with M446 loader
   / Help with M446 loader #1
Dmax
Bronze Member
ARKANSAS
KUBOTA M6800SDC
If any one here owns a bush hog m446 loader with cable control valve I need to know if you can you do two fuction at once? As in lift and dump or lift and roll back. If I try to lift then at the same time go to full dump it will stop lifting. Is this correct for a bush hog valve? They came out and adjusted my cable and it is better but still does not seem right. Thanks for any help
   / Help with M446 loader #2
I have an M2346 and it is set up the same way. I even asked my dealer about this as I have operated "Corner Control" joysticks and liked them. I was told BUsh Hog basically went the route to make the loader as stout as possible. I.E. if you were splitting pressure between two functions, you would lose overall capacity. Made sense to me. I think the 2 function joysticks are geared toward late model tractors with high pressure pumps. My Mahindra 5005 is not a good candidate for one so I just make do.
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2020 KUBOTA RTV...
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
