Help with KL120 measurements?
   / Help with KL120 measurements? #1
pekabu
Platinum Member
NH
TC24D
I was wondering if someone has a bit of time and owns this loader if they could take a couple of measurements for me? I am trying to figure out how far off from the 12LA loader this is. (bucket interchange)
1. Outside Width of loader arms at the bucket (preferably near the pins).
2. Inside Width of loader arms at the bucket (preferably near the pins).
3. Width of pins at the bucket (top and bottom)
4. Distance between the pins at the bucket.
Thank You
   / Help with KL120 measurements? #2
Someone might be able to measure the KL120 bucket brackets for you (I'll try this weekend) but you'd have to be spot on if you are going to make a switch. Those brackets will not work if you are more than a millimeter or two off without a lot of persuasion. I kinda doubt there is interchangability between brands. Companies like ATI sell a lot of buckets and they might be able to tell you if the buckets they sell for the KL120 and your LA12 are the same. I doubt it.
KL120 and KL130 do however share the identical mount.
It's probable that they are not close enough, but I swear they are the same loader. The look so close! What quick attach do you have on the front of that (Horst)? ATI has a pin one for the 12la, but has the Skid Steer one for the KL120. Even the specs seem similar. Roughly how much (if you don't mind me asking)? I am guessing around $600-$700.
   / Help with KL120 measurements? #4
I don't know who manufactured the QA adapter. I got it free from Millonzi as I was the first person to try to attach one of their grapples to a CUT and they were interested in seeing how it worked. It works very well. I don't think they made the QA adapter but I've never figured out who did. Not sure if they ever did put a QA adapter in production but they do sell the grapples and other attachments.
ATI makes a nice QA adapter too but I don't know what it costs.
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
1974 IH Farmall 1066 Tractor (A50514)
1974 IH Farmall...
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
2000 OSHKOSH MILITARY M1070 TRUCK (A51243)
2000 OSHKOSH...
