Help with hinge selection
   / Help with hinge selection #1
tshep
Richmond, VA
BX23 MLB
Did not imagine this would be this complicated.
So, shed with standard construction walls - 2X4, sheathing, J channel (about 3/4 outside sheathing) and vinyl siding. 2x4, sheathing outer edge of J all line up well to create door hole, finish rather than 'rough'.
I plan to build a 2 1/2 steel stud framed door, 1/4 plywood both sides, nice flat plastic glued exposed side. So, say 3 in thick final door, can move in or out of hole a bit as required.
HOWEVER, the door will need to open 180 or so. As it (and its mate) opens, I will lose 6 inches of hole width (as 90 door frame enters space) that I can get back with a full 180 opening.
I thought I would just put, say 4 1/2 'deep' hinges on, that could clear the J, barrel outside to weather, and the 4 1/2 depth would allow catching the wall stud and the door stud. Obviously (now) that leaves barrel pins exposed to thieves.
I did not plan on strap hinges, did not think I could get them to clear the J.
What do I want?
Need security, medium weight, close to 180, clear 3/4 or so of J past structure.
THX!
   / Help with hinge selection #2
They make hinges with nonremovable security pins.
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
DMI 13' Chisel Plow (A50515)
DMI 13' Chisel...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
