Help with Fuse Panel on 4520
   / Help with Fuse Panel on 4520 #1
JimmyC
Texas, USA
JD 4520
While clearing some cedar brush with my JD4520, the wires feeding my hydraulic diverter switch got snagged and were ripped from the back of the fuse panel. The diverter & switch were dealer installed when I bought the tractor and I guess they didn't get the wires tucked up out of the way. It looks like the wires were pulled out of the crimp connectors that clip into the back of the fuse panel. The local JD dealer can't find a part number for the fuse panel, let alone the pins that plug into the back of it. I need some new pins and a tool for removing the old pins from the fuse panel. Any ideas?
Thanks,
Jimmy
   / Help with Fuse Panel on 4520 #2
Thanks,
Jimmy
You could log into www.jdparts.com and try to find to #'s yourself
Or you could find another dealer who is more willing to help you!
Oh, and WELCOME to TBN!
I did look at JD's website for parts. I couldn't find a part number. You can see the "fuse holder" in the diagram for the wiring harness. That's when I gave up and went to the JD dealer in hopes that they would have better resources. They couldn't find the part number either. They are supposed to be putting in some sort of "case" to JD to get a part number and said that "maybe" I would have an answer by Tuesday.
   / Help with Fuse Panel on 4520 #4
If you get a responce from J.D. please post it. I tried (for an add on) and got the same responce from J.D. and the dealer. Like to hear more.
UNUSED Mini Excavator Hydraulic Thumb (A47477)
UNUSED Mini...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55302)
NEW 2025 Load...
1999 International 3800 DT466E (A53314)
1999 International...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
(2) Seats (A53316)
(2) Seats (A53316)
2014 Freightliner MT55 Step Van (A55788)
2014 Freightliner...
