I have a 755 and the injector pump is seeping at the connection below the injector line. I have reviewed the technical manual, but it does not show an internal breakdown of the pump. It just says if there are any issues to replace the pump. If you look at the photo I have attached, it is leaking between the pump and the nut. I have tightened that nut as tight as I can without stripping or damaging something. The tech manual for the engine says those nuts should not be tampered with because internal pump damage could occur. Does anyone know what is under that nut or how to fix this issue?
