Help with code 5-14 on 435 mini ex
   / Help with code 5-14 on 435 mini ex #1
turkeyleg
1964 jd 420
Any suggestions for my tractor throwing a 5-14 code. Supposedly it means low hydraulic pressure. Could a clogged hydraulic filter cause this?
   / Help with code 5-14 on 435 mini ex #2
If you have not changed filters recently that would be good place to start. If I remember correctly the pressure sensor is in the cooling fan circuit. Does the cooling fan run and change speeds as temperatures increase?
Changed the filter, no change in code. Tightened the idler arm, no change in code. We are testing the pressures tomorrow, I will look at the cooling fan circuit. Seems to the mechanic that its looking like the hydraulic charge pump or an electrical problem.
Thanks, will keep you updated
   / Help with code 5-14 on 435 mini ex #4
Could be just a weak sensor. The charge pump (system) sends oil through the cooling fan first, that is why I asked about the fan speed.
I will have to look at that, I wish we looked at that already. We are basically shooting in the dark trying to diagnose the problem. The 435 is still sitting in the woods, we sent the charge pump to be rebuilt and have not gotten it back from the dealer yet.
2024 JOHN DEERE 461M LOT IDENTIFIER 59 (A53084)
2024 JOHN DEERE...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
