Tractor Sizing Help with choosing size of tractor
   / Help with choosing size of tractor #1
POC
Southern Indiana
Mahindra 3215 4x4
I'm looking for a tractor, but don't know exactly what I need.
I use my dad's Ford 600 tractor (34hp?) for most things around here currently. I am planning on getting another tractor, but don't know which way to go, bigger, or smaller. The old Ford has no FEL, so it is not greatly useful. I bushhog with it, and scrape the driveway, sometimes yard some logs. I'd like a tractor that I could load logs with, on a small trailer, nothing bigger than 20" with forks.
I have big hills that are wet a lot on the place here.
I was thinking of something in the 28-35hp 4x4 range. But that is almost exactly what I have. Albeit I understand I'll have more traction with the 4x4.
But would the old Ford be better for baling hay than a similarly hp'd compact?
I've seen the pic that (sorry I can't remember your name) has of a Kioti with a bunch of wood in the FEL.
Could I yard and load logs with a 20hp tractor? I'm primarily looking at Mahindra and Kioti, but I'm open to others if someone has some good info for me.
I appreciate any help.
Patrick
Thanks for any advice.
   / Help with choosing size of tractor #2
If you're baling hay on hilly ground I think I'd want no less than 45 PTO HP, not to mention a bit of weight. It would be very easy to lose the Ford with a small mistake. In Kioti, nothing smaller than a DK55, in Mahindra, a 5525 (2wd only), 5500 (being discontinued), or 5530 would be the ticket. Mahindra also has a 5520, it's a bit more featured tractor than the others I mentioned. I'm assuming you will be using a small square baler. You may also want to look at the NH TT60A or the JD 5203, entry level utilities from those manufacturers, both at 47 PTO HP. I believe all of those I mentioned will price out very competitively with the "name" brand compacts. Each of the above mentioned tractors, without ballasting, also weigh nearly a ton more than the 600 Ford.
   / Help with choosing size of tractor #3
For lifting logs and baleing hay you are going to need more than a 20 hp compact. Some tractors that are categorized as compacts (like the JD 4000 series which starts at 43 hp) are larger and heavier than your Ford 600 and these would be more capable at any task than the 600 mostly because they have 4wd. I would look at only the largest compact tractors or at small utilities. 4wd will let a smaller tractor pull like a larger 2wd because there is no energy loss associated with pushing the dead axle, which also saves a lot of fuel for tillage work. For lifting heavy weights, and baleing however, 4wd is not worth as much as additional weight and power. With wet hills and loader work you certainly will want 4wd, but look for one that weighs as much or more than your 600. Mahindra has a nice selection of heavy 4wd's so I would check them out in addition to the JD 4000 series. I have a JD 4120 and it has held up real well for 3 years of hard use including lifting a lot of heavy logs. Whichever tractor you choose, get R1 tires, and make sure you get the rears loaded. R4's are nearly useless on wet hills, and loading the rears adds a lot of stability on hills and when lifting heavy loads.
dgl24087 said:
If you're baling hay on hilly ground ...
I wasn't clear here. Where I'd be baling is mostly flat, but most of the property (in the woods) is hilly.
Thanks for your input,
Patrick
   / Help with choosing size of tractor #5
Handling logs and baling with a small square baler are tasks that require a heavy tractor. The heavy tractor will be far more stable than the lighter ones. I would suggest you check out the Mahindra 4530 and if you are doing more than 10 acres of hay maybe the 5530. These tractors have the weight to keep the tractor stable when lifting the loads, if your tractor is to light a unbalanced log can get the best of you and tip the tractor. I just can not stress the importance of a heavy tractor enough, as it equals safety.
So it seems that baling hay is the crux of my problem here with the need for a big tractor. If I take that out of the equation, would a smaller tractor work for me?
We really only have about, maybe 25 acres of tillable/hay field. I could hire it out for a long time for the difference in cost of a big tractor vs. a small one.
I'm thinking now I'll look specifically at the Kioti LK30TLB and the Mahindra 2615 w/ FEL and BH.
Any more opinions?
Thanks,
Patrick
   / Help with choosing size of tractor #7
34hp from that 600 series is a bit anemic for hay bailing. I'd want higher. Aside from that, if you will be doing lots of loader work in wet slipepry areas.. deffinately get 4wd and power steering.
Are you only looking at new.. or will you cinsider used as well.
If used.. things like the ford 5XXX series will do all you need.
A 4XXX may do fine as well.. but you will need a newer model.. like a 4610.. etc.. to get some of the better options..
soundguy
   / Help with choosing size of tractor #8
Before you settle on the 30hp size, take a look at (and consider economics of) the Kioti DK40/45se and the Mahindra 4110/4530 size tractors. These are all fairly heavy 40hp range machines with pretty strong loaders that might come in handy with your intended clean up of logged land and some hay bale handling. It sounds like you are not running a large full time farming operation if you have managed with just the Ford without FEL up until this point so maybe you don't need a full size Ag machine but unless the tasks you describe are only occasional, it does sound like you need more than 26-30hp. You can move up from the 26-30hp to the 40hp class for a few thousand bucks. Most companies offer pretty good low finance rates these days and it is cheaper in the long run to stretch a bit now as insurance against needing to trade in on a bigger tractor next year.
   / Help with choosing size of tractor #9
once you take the baling out of the equation, you should be fine with any 30-40 HP MFWD model from Mahindra or Kioti. One thing I'm curious about is the 20" logs. -- what kind of tree and how long of pieces are you planning on moving, because loader capacity can come into play pretty quick here as green wood is HEAVY! If you're only going 8 -10 feet long, you might be able to go as small as a Mahindra 2810 or 3215. (althought the 4110 is a very nice machine, too) I'm not as familiar with the Kiotis, but I've heard very good things about them from those who do own them.
   / Help with choosing size of tractor #10
Island tractor, I'm pretty much in the same boat as POC but will not be bailing any hay. Cleanup from cut timber, haul some loga and then use the tractor for cutting pasture. Do you think the 4110 will be too big? somewhat concerned with weight causing ruts. 900 ponds heavier than the 3510 but I got what I thought was a great quote from a local dealer 4110 with ML112 $18,950 only $50 more than 3510
Bush Hog RMB 1865 Ditch Bank Mower (A50120)
Bush Hog RMB 1865...
2018 JLG 3246ES 32FT. Scissor Lift (A51691)
2018 JLG 3246ES...
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
10' Feed Bunk (A50515)
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
