help with brake caliper on deere 5310
   / help with brake caliper on deere 5310 #1
bigiron1974
WV
I need help. I have a deere 5310 that we have the axle housing off from. The brakes are dragging and trying to get the caliper out of the piston. Any suggestions or know how would be appreciated.
   / help with brake caliper on deere 5310 #2
i'm having the same trouble, did we get an answer?
   / help with brake caliper on deere 5310 #3
The following was taken out of the tech. manual hope it helps.
Remove piston assembly (C) using a pry bar. Pry at three retractor locations (D) evenly until piston assembly is removed.
See attachment for C and D
Please consider sharing how things went.
   / help with brake caliper on deere 5310 #4
thanks for info , got the old ones out with a slide hammer, not to worried about dammage, they were 12 yrs old, installed all new parts as per tech man. left side o ring did'nt hold . disassembled now , was hoping for a better way to remove the piston as not to f it up, they cost 200.00 , new o rings wil be here tomorow , hope its a better day,
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2020 JOHN DEERE 6145M LOT NUMBER 79 (A53084)
2020 JOHN DEERE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2020 Ram ProMaster 1500 Van, VIN # 3C6TRVAG5LE100108 (A51572)
2020 Ram ProMaster...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
