Help with an early (?) TL3200
   / Help with an early (?) TL3200 #1
hedg12
Wichita KS
Iseki TL3200
I'm in the process of doing an in-frame "overhaul" (rings, rod bearings, valve job) on my TL3200 & have run in to a problem getting the cam timing right. I have a manual for a White field boss 2-32, which all my searching tells me is the same tractor, but the White manual shows the engine (Isuzu 4fa1) having timing gears - mine has a chain. I've seen references to earlier versions of this engine having a chain, but I can't find those references now. The cam sprocket is tapered & there's a keyway on the cam, but not in the sprocket & (obviously) no key. Before I disassembled the engine I turned the engine so that the only indicator mark on the injection pump was at 12:00, and made a mark on the crankshaft at 12:00 and a mark that corresponds with the keyway on the cam that was also at 12:00. But now after I reinstalled everything I can't turn the engine a complete revolution (by hand) before it comes to a hard stop from what I assume is a piston hitting a valve. I'm pretty sure I have the timing close, but I can't find any information online for the proper procedure to set it. Does anyone have any idea of where I can find the information? Any help would be greatly appreciated.
Hydraulic and Coolant Radiator With Hydraulic Driven Fans (A47384)
Hydraulic and...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2020 FREIGHTLINER M2 26FT BOX TRUCK (A52141)
2020 FREIGHTLINER...
Wovlerine Quick Attach Bale Squeeze (A50515)
Wovlerine Quick...
