Help with a part number
   / Help with a part number #1
Piedmont
NC, USA
JD 2520
Does anyone have the part number for the lift pins that you use on the 62D MMM? And is the spring locing pin mentioned in the manual the same pin or is that a different part if so I guess I'll need that number as well.
Did anyone get these as standard equipment with their deck or is an option?
   / Help with a part number #2
Get all part numbers on the John Deere website /Parts
I don't consider myself the sharpest knife in the drawer but based on this how do you suggest I go about that?
The site brings up this message...
No Part Types for this model
Well well, I drilled down a little deeper and found my answer.
Lift pins M151713
Locking Spring Pins A15147
   / Help with a part number #5
Piedmont, What are you entering into the Model Type box? I just entered "62d" and got to it, But I am not sure what parts you are refering to?
I went to the Alphabetical Index, then to the L's, then selected "Lift Linkage,Mower Deck(mech lift)2520
Kenny
   / Help with a part number #6
I guess I'm late as usual;)
Glad you figured it out! JDParts can be a PITA at first, but once you get used to it, it's the cat's meow-and the envy of all other colors:D
Kenny
10-4 on the JD web site a bit of a PITA but I think I have the hang of it!
   / Help with a part number #8
Kenny is a pro at looking things up on JD parts.:)
by the time i get started he has already found it.....;)
Chris.......:)
Club Car Electric Cart (A55758)
Club Car Electric...
200387 (A51247)
200387 (A51247)
2430 (A51248)
2430 (A51248)
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
