Help with a JD serial #
   / Help with a JD serial # #1
ThistleKop
Mid TN, USA
175 Allis, 1975, Case IH 895
Hey folks I need some help with the translation of a JD serial #. I've looked for a previous thread, but so far haven't found it, that breaks the code. I'm primarily interested in the model yr. and where built. Looks as if it's a 5320 turbo. Here's the number: LV5320S332746. Thanks.
TK
   / Help with a JD serial # #2
You'll have to let a JD dealer look the serial number up for you. The only thing the serial number tells is model number and what type tranny.
   / Help with a JD serial # #3
TK,
Here is the link to the previous thread explaining the breakdown
POST
   / Help with a JD serial # #4
Base Machine Code:601DLV
Component Serial Numbers Serial Number Component Invoice / Transfer Date
C0000520L ROPS-LH 15Jul2003
C0002244C ROPS-C 15Jul2003
C0205720R ROPS-RH 15Jul2003
LCAR324054538 AXLE,REAR 15Jul2003
L0AR324054537 AXLE,REAR 15Jul2003
PE3029T261345 ENGINE, D. 15Jul2003
TU035183 TRANS, TOP 15Jul2003
143410001335 TWO WD FA 15Jul2003
Build Codes Code Description Invoice / Transfer Date
1000 2 WHEEL DRIVE AXLE 15Jul2003
1505 OPEN STATION 15Jul2003
2005 SYNCSHUTTLE TRANSMISSION 15Jul2003
3000 VERTICAL EXHAUST 15Jul2003
4055 16.9-30 R1 STEEL WHEELS 15Jul2003
6200 9.5L-15 6PR F2 15Jul2003
7000 LESS REAR SCV 15Jul2003
7200 LESS MID SCV 15Jul2003
7500 FLAT BAR DRAFT LINKS 15Jul2003
This is the original order code info for the serial number you posted. Hope this helps
Thanks Ron and all who responded. That is a tremendous help. I'm considering buying this tractor. Looks as if it was built or sold in July 03 depending on what the transfer date on all the components means. Wonderful folks on TBNet.
TK
   / Help with a JD serial # #6
This is what comes up in the Warranty network -
PIN: LV5320S332746 Model: 5320
Customer:
Phone:
Settlement Date: Previous Owner: NO
Sold As: Open PIPS: NO
Claim History: NO Last Reported Hours: 478
Rent Status: MACHINE IS RENTED Rent Days: 111
Warranty Information
BASIC START DATE: BASIC EXPIRATION DATE:
RENTAL UNIT
Engine Emission: Expected Use Date:
Dealer Information
Selling Dealer: 01-0232-DIXIE, GA Phone: 229-263-4133
Responsible Dealer: 01-0232-DIXIE, GA Phone: 229-263-4133
Stephanie,
Thanks for the info. I found that the JD 5320 that I was interested in was put in service by the Boston Tractor Co in Dixie, GA. Another JD dealer was very cooperative and found this for me. When I called the Boston Tractor Co. they had no interest in looking the owner/renter history up for me. Prior to this A person in my hometown made the statement that a tractor he had recently acquired might be one of those "Georgia tractors" and there's no telling how many hrs. it really has on it. I don't know what he was referring to. Can any of our Georgia friends shed any light on what may be going on in that area? Thanks.
TK
   / Help with a JD serial # #8
I am not from Georgia, however we have purchased some of the larger tractors from lease returns in that area. We refer to them as sugar tractors. They have been leased from JD company and used for one year. When we get them they have about 1000 hours on them and still retain full factory warranty. As far as the number of hours, the only way that can be altered is by replacing the tach. When the tach is replaced it has to be documented to be leagal. When doing a PIN search on the tractor you are interested in, I saw nothing that would raise any red flags for me. Good luck in your search. /forums/images/graemlins/smile.gif
   / Help with a JD serial # #9
Tractors from the south are notorious for being used for thousands of hours and either having the hours turned back or having a new hour meter put on them. On the older tractors they will be painted to look like new and be falling apart inside. In the south tractors can be used year round for field work. In the northern states unless you have livestock your tractors are usually idle for 4-6 months in the winter.
And just to clarify it's not illegal to put in a new hour meter. It is on cars but not tractors. At least not in any of the states I know. It's illegal to misrepresent if you know but hour meters are replaced all the time and never certified. Even the dealers don't do it. I've called on numerous tractors and alot of times they will even put in a new hour meter if the engine was rebuilt. If you ask how many hours before the rebuild they don't have a clue.
   / Help with a JD serial # #10
That is indeed the case with tractors handled by "iron jockeys", however this tractor has never been settled for or delivered. It would not be in the dealers best interest in this case to try and alter hours. More than likely it will still have some or all of the original warranty on it. Warranty usually starts from the settlement date.
I think that any of us that have been around larger tractors for any length of time have seen horrible examples of tractor abuse and cover up on some of the older southern tractors, but I would not be too afraid of the tractor originally mentioned in this thread. /forums/images/graemlins/wink.gif
2014 Infiniti QX60 (A51694)
2014 Infiniti QX60...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51691)
2019 Ford F-550...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
