Help with 870 JD
   / Help with 870 JD #1
Ronus
Burfordville MO
JD 870
Last fall, after I took a break, went back to start tractor and it was dead. I was able to jump start it at the starter and drive it home. The starter was original and it dragged horribly, so I replaced it. The key switch was very loose, had to hold it with one hand and start it with the other, so I replaced it. It still has no power, the dash lights won't even come on, any ideas?
   / Help with 870 JD #2
Sounds like you are not getting any power to the wiring harness threw the ignition switch. I would look for any loose connections. Sometimes the wires pull out of the plastic plug and loose contact. I might even be rodent damage, looked for chewed wires. Its going to be a trial and error to see whats getting power and whats not.
   / Help with 870 JD #3
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2014 PETERBILT 388 (A53843)
2014 PETERBILT 388...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
Bryant 650AN048-E A/C Unit (A52377)
Bryant 650AN048-E...
1995 Western Star 4900 T/A Wrecker Tow Truck (A53422)
1995 Western Star...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
