help with 3pt lift.
   / help with 3pt lift. #1
Lickity Split
Germantown WIsconsin
MF65, Toro Groundsmaster 72
I have a older Massey Ferguson 65 that has a 3pt lift.
The problem that I have with it, I have a box scrapper attached to it, after 10 minutes with it in the up position it will start to slowly lower down and will not come back up.
I changed the oil, it was all milky water in it.
put new oil in and it does the same thing.
I have the lifting lever in the up position, but it just falls down.
The only way I can get it to raise is to turn off the tractor for 10 minutes and start it up and it is like new for 10 more minutes.
I can move it up and down for the first 10 min but then it just stays down.
The new oil that I put in ( trans-hydro oil) looks good and is not milky.
Thanks Lickity Split
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
1992 GROVE AP-308 CRANE CRANE (A53426)
1992 GROVE AP-308...
2012 CATERPILLAR 299D XHP SKID STEER (A51246)
2012 CATERPILLAR...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
