HELP very frustrated with 60"mmm
   / HELP very frustrated with 60"mmm #1
cglenn
I have a low hour(17 hrs) cub cadet 7254 tractor with a model #291 60" mower deck. The mower deck has broken two(2) idler pulley tension springs and constantly throws the belt off the deck. I cannot even get 10 minutes of mowing in before either the belt throws or it breaks the spring. Is there an engineered solution for this as my research show that this is a prevalent issue. Some mention was made of a upgrade to the belt tension system via the addition of a 2nd idler pulley. What are the part numbers for the kit ? Where can I obtain this kit ? Is it available for my mower deck? If not what would be a solution to my issues.
:mad::mad:
   / HELP very frustrated with 60"mmm #2
There's a gotta be something wrong with another component in the system; A sheave or spindle with bad bearings, severely bent pulley, one pulley/sheave out of plane with the others. I'd eyeball everything, check for plane with a straight edge the best you can and give everything a spin by hand with the belt off to check how well they roll. It a start anyway!
Joel
   / HELP very frustrated with 60"mmm #3
Warranty?
:mad:unfortunately no warranty. Tractor was used and is several years old.
:mad::mad:
correct mower deck model # 590-614-100
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
(2) Ford Suitcase Weights (A50515)
(2) Ford Suitcase...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
