Help transmission fluid
   / Help transmission fluid #1
Acresfarm
Farmtrac 545
I recently changed the transmission fluid on my 2004 Farmtrac 545 and it is now hard to shift into gear. It did shift smoothly in all gears before changing fluid. The fluid that came out was thick and milkly colored. I replaced it with the recommended specs and used the premium tractor supply hydraulic fluid. What is causing this? What fluid should I change to? Recommendations please ?
   / Help transmission fluid #2
Being that the fluid was milky, it probably had moisture in it. Many shift shafts for shifting gears will get rusty and will become hard to shift. Get some penetrating lube and spray the shift linkages and pivoting shafts going into the trans case. While doing this, really work the levers.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
91013 (A48082)
91013 (A48082)
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2020 McLanahan 150 TPH USP Wash Plant (A52377)
2020 McLanahan 150...
