Help! Tractor won't start!
   / Help! Tractor won't start! #1
HuntsEndFarm
Maryland
JD970 & Ferguson TO35
Help! Tractor won\'t start!
Went out this morning to use the tractor (JD 970), turned the key and got nothing but a clicking noise. It tried to turnover once or twice but only briefly and went back to the clicking. I hooked the jumber cables to it just to make sure the battery had enough power and that didn't help, still the clicking. It's been about 6 weeks since I've been able to use the tractor so it's been sitting a while.
Is this a starter problem? Please help.
Mike
   / Help! Tractor won't start! #2
Re: Help! Tractor won\'t start!
I would go back and try to jump start it. I don't think you
had a good connection ground or pos. Also cheap booster cables will not carry enough juice to jump a dead battery.
Good luck
   / Help! Tractor won't start! #3
Had a similar problem with my <font color="green"> JD </font> F735 a couple of weeks ago. Thought it was a bad battery. After checking out the whole system, found that the ground wire from battery was loose at the engine end. Since tightening I have not had a problem starting.
That was it! Don't think I had a good ground. Found some bare metal and it started right up. /forums/images/graemlins/smile.gif Thanks for the help!!
   / Help! Tractor won't start! #5
I've had this problem with our 32' diesel trawler with a 60hp Isusu 4cyl engine. It's always been corrosion in terminal fittings, splices or just corroded wire...never the starter or batteries. Marine life is tough on electrical.
   / Help! Tractor won't start! #6
Maybe new battery time. Same thing happened to out 970.
   / Help! Tractor won't start! #7
Just this weekend I ran into one of the safety features on my new 990: the tractor will not start if the PTO is engaged. Not exactly the problem you seem to be facing, but it gave me a good scare when I went thru my start up procedure and got nothing. A careful check of everything showed me my mistake.
   / Help! Tractor won't start! #8
Oh, don't worry you will get used to that nice 990. Our 970 had a good Yuasa battery that was the original battery until last year when it went dead.
Landoll (A50657)
Landoll (A50657)
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2008 CAT 287C (A50854)
