help to identify vintage of 8N
   / help to identify vintage of 8N #1
freetown fred
Freetown, NY
Ford 8N
Got numbers off block--8N508624--diamonds on either end--that 6 is real unclear--just a guesstamit on my part.
   / help to identify vintage of 8N #2
mid late 52.
mines 504xxx
sn starting for that year was:
1952 442035
soundguy
mind you.. that's the engine vintage. since all 1939 thru 1952 8n-9n-2n engines, and the similar 119ci flathead industrials from pumps and gennies all would swap.. it just tells you engine.
you can look for clues on the tractor to further id it as late. like steerinmg box, and most importantly, hump in trans. then again.. all that stuff will swap too. axle date codes can help.. etc.
post a pic of her from the side.
   / help to identify vintage of 8N #4
here's a pic of a later steering box and the hump in the trans if it has the trans hump.. trans is a 52
also shows a thin and thick upper lift arm. the thick one is a later 52 design.
hth
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2017 Freightliner M2 Cab & Chassis (A53117)
2017 Freightliner...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
Equipment Trailer (A53117)
Equipment Trailer...
Valvoline Transmission Oil / Power Steering Fluid (A53117)
Valvoline...
