I was out doing some hogging today and the DK40 started leaning to one side. I looked over and the right rear tire was running low. Took it back to the barn and saw that something had cut or punctured the tire
. (At least it was on the tread, and not the sidewall.) I think it can be repaired, but how? What do I do now? I tried to loosen a couple of the bolts holding the tire on w/ my half inch socket. Those dudes are on there tight...more than 200ft.lbs according to the manual. Should I just try to find a mobile tractor tire repair guy to come and fix it? Should I remove it and try to take it to a tire repair store? How heavy is that tire and will I be able to lift it into the back of my pickup? I will probably have to go get a longer breaker bar and/or and impact wrench to get those wheel bolts loose. Any help would be appreciated. Thanks.
