DaveInColorado
I got my BX1500 a couple of weeks ago off Ebay - it was a great buy and all that - but I didn't get (nor did I ask) any explanation on how to attach the tiller! It is a Land Pride, but I don't think the brand matters. The driveshaft is too long and I read about shortening it but I've so far cut 2" off both sides and it can barely be jammed into the space between tiller and tractor. I put my questions in logical order:
1 - After a couple of hours screwing with it several different ways, I've pretty much concluded that the tiller must first be completely attached before putting on the driveshaft. I came to that conclusion after the impossible task of trying to line up the splines with the tines on the ground. Am I correct?
2 - Driveshaft length - how much "extra" space will probably be along the length? If I get it where it barely fits, is that good enough or should I shorten it another inch or so to make sure nothing binds?
3 - What about this @#$*& plastic shield around the driveshaft? Everything would be a whole lot easier to view/cut/install without that dumb thing. However - I do have small kids and though it would be a terrible idiot thing if they were ever between the tiller and the tractor while either was running (and tines turning on tiller), I guess I'll relinquish my eternal quest for efficiency and keep that thing on the shaft. But - how would I remove it if I wanted to? It has Lock and Unlock directions, but I squeezed, pulled, pried and never got it to budge and come off each half shaft.
4 - I would appreciate some feedback from someone who has put a tiller on a BX tractor. I haven't measured mine but I believe it is only 34" wide.
/forums/images/graemlins/confused.gif in Colorado
