Buying Advice HELP.. THINKING ABOUT 3038E
   / HELP.. THINKING ABOUT 3038E #1
MATTS875
I have priced out a John Deere 3038e with a FEL for $16300 total out the door.Can I buy a better tractor for that money or maybe a little more?I have looked at the Kubota L3400 with a FEl and without the Hydrostat trans. for $17500 total.Not sure if I would miss the Hydro ..never had it before.I can get 0% for 48 months on the JD and 0% for 60 months on the Kubota.I know this might be a flip of a coin, just need a little reinforcement.I am also not too sure about the JD 3038e Yanmay Turbo Diesel engine..not sure of the maintenance.I can buy the 3032 with a FEL for 15k out the door.any help would be greatly appreciated.
   / HELP.. THINKING ABOUT 3038E #2
That price is a little lower than what I was quoted for a 3038e last year. When I priced them the 3038e was about $1K cheaper than the L3400 hydro.
Here is the scoop between the two tractors. Both tractors are considered "budget" tractors. The difference between the L3400 and the 3038e is as follow:
The L3400 does not have a turbo, the JD 3038e does ( I prefer no turbo). The L3400 Hydro has cruise control standard, the JD does not. The L3400 has a drawbar std, the 3038e does not. The L3400 has Foldable ROPS at no extra charge, the 3038e does not. The L3400 has a temp gauge and fuel gauge, the 3038e does not. The L3400 has a split brake, the 3038e does not. There is some controversy over the position of the split brake on the L3400 so check it out before you buy.
The 3038e does have two pedal hydro, which some people prefer, but I like my setup on my L3400 so it's no big deal to me. The 3038e is a nice tractor. I tested one out before I bought my 'bota. IMO J.D. left those features off so it would not compete directly against the 3x20 series. Also, there is no option to leave the PTO running without being on the seat for things like a PTO generator. Also, the 3038e is all plastic, the 'bota is all metal. I really like mine.
   / HELP.. THINKING ABOUT 3038E #3
Oh, and I paid $18K out the door for mine in Nov. with ag tires and FOPS. Good luck.
   / HELP.. THINKING ABOUT 3038E #4
Before you buy either the 3032 or 3038, do your homework. Both are "Economy" tractors and they have certain limitations that you may not be aware of.
   / HELP.. THINKING ABOUT 3038E #5
I'm not sure you will need the extra hp with this tractor....especially with 5 foot implements (3038 vs 3032) unless your doing mostly heavy PTO work: tiller and brush hog.
I find that 30 hp will spin the tires before bogging the engine....(but the 3032 is a bit heavier than my 790)....so that deal for the 3032 may be pretty enticing if your on a budget. :confused: ;)
I wish Roy would expand on "certain limitations".....lol.
After having some seat time on my used 790.....I would buy a hydro or a shuttle tranny if buying a new tractor. So much nicer for loader work and for close quarter maneuvering.
OH....and welcome to TBN Matt!!....use the search feature to get lots more posts on these tractors....and ask more questions!
   / HELP.. THINKING ABOUT 3038E #6
One other thing that could be a big factor for your decision: the Dealer and his proximity to you. Also, the parts availability and how well you "get along" with the dealer.
For me, the proximity and parts for the JD make it any easy decision.
   / HELP.. THINKING ABOUT 3038E #7
I have about 4 hours ob my 3032 and I love it. I am fan of the two pedal hydo. I have had a rocker hydo (TC33) and it worked but like two better. Do some home work, these posts help so much. Do what works best for YOU!
Have fun hunting, :thumbsup: :confused2: :drool:
THANKS for the advise.I went and finally got to look at both the JD 3038e and the Kubota L3400.First time to be on both.not putting down the Jd at all but the Kubota does have a lot of nice features that I like.I think I am going this weekend to negotiate a price on a new kubota l3400 with FEL. I was quoted 17500.00 total out the door for one that did not have the hydrostat trans. I think I am ok with that.The only adds I like are the r4 industrial tires.The kubota just felt more solid.all input is appreciated. I think I am about to over analyze this whole thing.thanks again
   / HELP.. THINKING ABOUT 3038E #9
Can't speak for a hydro, but I now have the Power Reverser on my 3320, it is nice for loader work, took a little getting used to at first, but I've got 58 hours on it now & it's starting to become 2nd nature to me. Keep in mind foggy, if you go with the JD PR'r it does not act like the shuttle shift found on most of your construction type Backhoe's; the power reverser is moving the minute the lever is moved into position not when you accelerate as on the commercial equipment, you may still be using your clutch, just a lot less.
   / HELP.. THINKING ABOUT 3038E #10
I haven't tried the Kubota, and definitely not knocking them as they make a nice tractor, but if it has a rocker hydro pedal, try using it for an hour or so before you make your decision. I have very strong calves from years of playing soccer and other physical activity, and those pedals still fatigue my calf after a couple of hours. I really do not like rocker pedals I have found out. I'll take a 2 pedal setup any day of the week as I can easily rest my heel which means less muscle fatigue. Just something to consider...
BTW - I have the PR on my 3520 and I love it. Hydro would be nice sometimes, but I am never cursing having the PR. I actually really like it a lot. Now when I get on our old JD big tractor, then I start cursing. Heh
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
1991 John Deere 4755 Tractor (A59814)
1991 John Deere...
Dell Servers (A56860)
New/Unused AGT Industrial QHT500FL Mini Tracked Dumper (A57453)
New/Unused AGT...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2014 Freightliner 108SD Crane Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
