Help the Wasps are Back
   / Help the Wasps are Back #1
TURKEY131
NJ
Kubota L35, RTV500, L5030, Kioti DK55c
I was wondering if anyone has any suggestions on how to get ride of these things. The wasps have built a nest under the fascia by the roof line. I was going to use some spray foam along the edge and seal them in there. Is there something I could spray or use to keep these things away from my house?
   / Help the Wasps are Back #2
I would use the 20 foot wasp spray and get about three cans then saturate all along the board. Retreat if they come back. had same issue a few years back and have not had issues for awhile now.
   / Help the Wasps are Back #3
The spry stuff is very effective, but doesn't get the ones out flying around somewhere.
A shop vac and long hose is also a good tool. Use the spray and the vac. Get all you can and take your time to get the returning ones, then destroy the nest.
All the activity might make a few of them go after you so be careful.
I got rid of an underground nest this way and then burned it out. Only got stung lightly once.
It was worth it to get rid of those nasty pests.
   / Help the Wasps are Back #4
I would only add, be sure they can't migrate INTO the attic. I would do this by spraying there first or better yet making sure it's well sealed off. You might like to begin that just before dawn so it's as cool as it's going to be all day there. Cool wasps = slow bugs
When I sprayed out side, they just moved inwards. I will tell you that wasn't much fun removing that mess.
G'luck,
M
   / Help the Wasps are Back #5
We get them every year. The spray foam after dark works well. If inside, shop vac works well, but don't spray killer into it as the spark from the motor might just blow everything up in your face. Wait a few days after sealing the vac up, then with the motor off spray into the bin, lift the lid off an hour later, and dump.
   / Help the Wasps are Back #6
Best time to mess with them is when the temps are around 45 or lower.
   / Help the Wasps are Back #7
I have them every year. I have cans of wasp spray everywhere. I spray the soffit vents, giving them a good soak . As they come an go they get a little of the residual on them and eventually die. This is good for about a month or so then I repeat.
I also found that you get what you pay for.. Cheap spray doesn't work as well as the "Name Brand"
Wedge
   / Help the Wasps are Back #8
I have never used bug spray, the shop vacuum method works great for all kinds of bees and wasps. I had a really long reach last fall for a nest way up in the eaves, and even putting togther a half dozen shop vacuum wands wasn't long enough. I used two sections of 2 inch PVC pipe cemented together to make a 16 foot long wand, and a 2 inch rubber flex coupling with hose clamps was the ideal way to connect a shop vacuum hose to the PVC pipe. Leaving the bugs in the vacuum tank for a few days is usually enough to kill them, especially if you leave the tank in the sun to heat it up.
   / Help the Wasps are Back #9
The cooler the better, I try to deal with them as early in the am as possible.
I have used starting fluid in the spray can and it works instantly, amazing fast.
   / Help the Wasps are Back #10
I get a boat load of them every year. I use the spray, but first I like to hang those trap bags near the nest first. Seems to catch most of them in just a few hours, then I spray the nest (AT DUSK). Couple days later, I knock the nest down and toss it or burn it. If I have to spray the nest during the day, I arm myself with a badminton racket. Very easy to knock them out of the sky using that racket. Then I just step on those.
For the yellow jackets, which nest in holes in the ground, I use the bag method (I get those bags at lowes for 5 bucks). Then I cover the hole with compost. Usually a bucket full from the FEL. Leave it for a week. Gets really hot under there. Never had them dig out yet.
I have been stung once.......... the first time I tried to spray a nest in the afternoon. That's when I went to using the bags. Those **** things hurt when they sting.
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2121 (A51244)
2121 (A51244)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2008 CATERPILLAR 226B2 SKID STEER (A51246)
2008 CATERPILLAR...
