Help!! Rotary Cutter Blade Assembly Removal
   / Help!! Rotary Cutter Blade Assembly Removal #1
shesh
Ariss, ON
Kubota 2920 HST
Hi, the gearbox on my rotary cutter is toast. I can't get the blade assembly off so I can remove the old box. Details in this video.
Shared album - Shesh Maharaj - Google Photos
Has anyone seen this style of blade assembly and how is it removed?
Thank you!
   / Help!! Rotary Cutter Blade Assembly Removal #2
Should have a access point from above the deck to unbolt retainers holding the blade pins in place
   / Help!! Rotary Cutter Blade Assembly Removal #3
It's probably a tapered fit, get yourself a two jaw puller, put the bolt in loose (at least a couple turns out and keep loosening it as it comes out) for the center bolt of the puller to push against and just go for it, put the jaws on the step of the external part around the shaft, easy peasy.
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A49461)
2011 Kenworth T300...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
DRIVELINES (A50854)
DRIVELINES (A50854)
KENWORTH  DIGGER TRUCK (A50854)
KENWORTH DIGGER...
197637 (A50459)
197637 (A50459)
