HELP - Restoring B7100D with B219 FEL
   / HELP - Restoring B7100D with B219 FEL #1
Phoenix, Arizona
Kubota B7100
I am restoring a '78 B7100D with a B219 FEL. The FEL was repainted at some point and I need to know the correct original paint scheme on the late 70's B219. I have seen photos that indicate that it was Kubota Bright Orange with all 4 cylinders and the bucket painted in Kubota Blue. Can anyone confirm this or offer a different opinion on the correct paint scheme?
Thanks !
   / HELP - Restoring B7100D with B219 FEL #2
Thanks !
Orange with blue cylinders and bucket is what my b219 was. I had to do some re-work on it to fix cracks and repacked the cylinders a the same time. I ended up painting the cylinders black... I think it looks pretty good. Have you found a paint code or something that matches the original blue? All I could ever find was people talking about the shades of orange.
So, that must be the paint scheme. Thanks!
There are two oranges, the early tractors used "Bright Orange I" and later tractors (1989and newer)used "Bright Orange II". The "Kubota Blue" only applies to tractors prior to 1989 after that, I believe they went to gray. All of these paints are available from Kubota in spray cans, quarts and gallons.
The part numbers for the "Kubota Blue" are 70000-00197, 198 and 199.
2017 DB800XL Dual Dustless Blaster Trailer with Rotair 425CFM Compressor (A48837)
2017 DB800XL Dual...
2015 JOHN DEERE 323E SKID STEER (A50458)
2015 JOHN DEERE...
NEW 2024 LOAD TRAIL 83IN X 20FT Tandem Axle Equipment Trailer (A50397)
NEW 2024 LOAD...
UNUSED LANDHONOR DDSL FUEL TRANSFER PUMP (A50460)
UNUSED LANDHONOR...
2010 Scion xB Hatchback (A48082)
2010 Scion xB...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
