Help removing a injector pump from a 2006 Jinma 284 tractor. The engine is model 385
   / Help removing a injector pump from a 2006 Jinma 284 tractor. The engine is model 385 #1
Warnestacey
Milton Freewater, oregon
2006 Jinma 284
Does anyone have any experience in doing this. I have everything loose on the pump side but the gears on the timing side are still in tact. Therefore, I can't pull out the pump. Please help.
   / Help removing a injector pump from a 2006 Jinma 284 tractor. The engine is model 385 #2
I'm pretty sure you have to pull the front cover off, and remove the gear off the pump. You might try post this in the Chinese tractor section.
2019 Nissan Rogue SUV (A50860)
2019 Nissan Rogue...
2019 Ford E-450 Super Duty Passenger Bus (A48081)
2019 Ford E-450...
Toolbox (A50860)
Toolbox (A50860)
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
