Help please to drain fuel tank
   / Help please to drain fuel tank #1
joesb1
kubota bx2660
I added gasoline to fuel tank, I add about two gallons of gasoline to my fuel tank. Need to drain tank. How do I drain fuel tank on a Kubota BX2660 tractor?
   / Help please to drain fuel tank #2
The easiest way I can think of is to use a fuel pump.
How much fuel does your tank hold?
E/S
   / Help please to drain fuel tank #3
As I said on your other thread, simply disconnect the fuel filter that is under your tractor. You'll see it, it is a simple in-line type.
That mix won't be good for anything but starting a burn pile, and a awfully big on at that!!!!
Hopefully you didn't turn the key or try to start it.
   / Help please to drain fuel tank #4
Not familiar with the BX line but could you remove the settling bowl and fuel filter and let it drain into a container? Would be a little slow but should work.
bp fick posted as I typed, sorry for the doble post.
   / Help please to drain fuel tank #5
This is what you are looking for. Under the tractor, ahead of the HST, under your driver position.
   / Help please to drain fuel tank #6
time to get different colored cans for diesel and gasoline.
   / Help please to drain fuel tank #8
Or Sharpie:)
I use different colored zip ties on the handle of the can for gas, #2 diesel, #1 diesel, etc & write on the cans what each color is for. That way, when filling the cans with something different, just cut off the old zip tie & change to the appropriate color.
   / Help please to drain fuel tank #9
I have a Kubota L3350 and would like to clean fuel tank ,can anyone tell me steps to do so . Dorrie
   / Help please to drain fuel tank #10
First off, welcome!
If you have crud in the bottom of your tank the following is what I have seen my dealer do.
First drain the tank or wait until there is very little fuel left in it.
Next get a shop vac, about 3' of water hose and some duct tape. Duct tape the water hose to the end of the shop vac nozzle with about 6" of overlap between the hoses.
Then open the fuel cap and start fishing the sludge out.
People have argued that this is unsafe, but I've seen it done multiple times. The Mythbusters even proved that it was hard to get a shop vac to explode while sucking up gasoline. (Gas is explosive, while diesel is only flammable.)
Is your tank clogged or what is the reason for cleaning it?
Informational Lot (A44786)
Informational Lot...
PALLET OF PIPE FUSION SUPPLIES (A45333)
PALLET OF PIPE...
2020 MACK PINNACLE (INOPERABLE) (A45046)
2020 MACK PINNACLE...
2009 PETERBILT 367 TWIN PUMP CEMENT TRUCK (A45333)
2009 PETERBILT 367...
More info coming soon! (A44571)
More info coming...
2018 Ford F-150 XL *Engine Knocks* (A44501)
2018 Ford F-150 XL...
